Hi everyone :)
I've been thinking a lot lately about buying RGB LED's for my case because I have a header on my Asus Z270-A that supports it. The only issue is that I have a Cooler Master MasterCase Pro 5 and have no idea what a good length would be since I'm really bad at math. Does anyone here have the same case and uses RGB LED's? The other thing is I'd really like to avoid using the remote controls, but also want LED's that will last. Price isn't an issue as my budget is endless.
Thanks in advance!
"The only thing that matters right now is that you're here, and you're safe."
https://linustechtips.com/topic/805102-case-rgb-leds/
Hey,
I could recommend getting a cheap, long strip from eBay they work well and can be cut to any length, they will also likely work quite well for the case. If you do want to get some that are good for the case I would recommend magnetic ones as these are likely to be much better.
Hope this helps,
TT
https://linustechtips.com/topic/805102-case-rgb-leds/#findComment-10116755
11 minutes ago, TurtleTrain said:
Hey,
Hope this helps,
TT
I'm actually using Amazon from Canada to see what they have. Can you take a look for me and see if there's anything you can recommend? I'd really appreciate it.
https://linustechtips.com/topic/805102-case-rgb-leds/#findComment-10116808
Hey,
These should work for you: http://amzn.to/2u1zJbt
They come with a power supply and remote however you should be able to power these from the header on your board
The shorter ones: http://amzn.to/2sEWRcb
These are also an option as they do not need to be modified much due to the fact that they are cut down, this does however mean they are more expensive
Hope this helps,
TT
https://linustechtips.com/topic/805102-case-rgb-leds/#findComment-10117536
