Hey guys,
I have had this monitor (ViewSonic XG2401) for a month now, and it never worked with FreeSync.
Now, I don't really need it as I never experienced tearing and I don't want to reduce input lag as much as possible (I know it's much lower than VSync, but still something for Overwatch/CSGO).
However, it would be nice to get it working as I know it is capable of doing it.
In Radeon Settings if I go to the display section it says that FreeSync is not supported. My RX 580 is connected to the monitor through a Display Port.
Any idea on what could be the culprit? Online threads usually say that it works automatically as long as it's DP, but not in my case.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/804701-freesync-not-working-xg2401/
5 minutes ago, Eibe said:
Hey guys,
You need to go into the monitor settings and enable FreeSync too.
8 minutes ago, Eibe said:
Hey guys,
you need to enable it in the monitor menu,
You have to enable freesync in the monitors on screen display, fiddle around with it and you should eventually find it. If you've already done that and tried to enable it maybe update your drivers? and if you've already done both of those things i'm out of tips in this department. good luck! xD
