I have a qustion, i use a Cooler Master CM 690 III case, whit a 200mm standard intake fan in front and a 120mm exhaust fan in the rear, i just got a Corsair H100i cpu cooler and i wonder, if it will be best to place the fans as intake or exhaust on that, when it goes in the top of my case. Hop u can help its the first time i use hydro cooling.
https://linustechtips.com/topic/80458-first-time-whit-hydro-cooling/
When mounting the radiator to the top of a case, you'll want to have it exhaust air through the top - If you need further clarification, I could whip up an image.
Did an image anyway, had time ;P
http://i.imgur.com/iVU998I.png
Spoilers don't work o-O Odd.
Okay thanks for the quick answer, then im gonna mount the h100i right away.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
