I was looking to get my setup back to looking better. I noticed I have these cable all sticking out of my pc. I was wondering if there was anything I can buy to make them all into one long cable. Is there something like a black cable sleeve? Like where I can just shove the cables in and close the sleeve and boom. One gigantic cable
edit: It's about 10 cables in total sticking out of my pc
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/803737-cable-management/
Absolutely, I forget what they are called. They are like a windy plastic pipe, that way you just wrap it around the existing wires. But I can't remember the name...?
Samuel Edwards
- IT Engineer and Media Producer -
Religious theology diploma and over half a dozen certificates in Advanced Computing and IT.
Current Project:   Mineral Oil Cooled PC
Just trying to be friendly and help where I can. Have yourself a great day!
Use @SamuelJE for friendly tech help :)
Main PC - "The Genesis"
Mobo   -   Gigabyte GA-H170-Gaming 3
CPU     -   intel i5-6600K 4Ghz on water
GPU     -   MSI GTX970 "Red Dragon"
Case    -   Zalman Z11 Plus (Custom RGB Obviously, It's 2017 bro...)
OSD     -   Crucial 275GB M.2 SSD
SSD     -   Crucial 250GB SATA SSD
HDD    -    4TB WD Green x 2
Disp     -   LG ultra wide Gaming Monitor
Secondary PC - "Jonah"   (Mineral oil PC)
Mobo   -   Gigabyte GA-B250-DH1
CPU     -   intel i5-7500 Under Oil
GPU     -   Nvidia GTX 660 (Favorite and first ever GPU)
Case    -   A Fish Tank W/ Custom Engineered Mounting System (Custom RGB Obviously, It's 2017 bro...)
HDD    -    2TB WD Green
https://linustechtips.com/topic/803737-cable-management/#findComment-10103047
YEs something like that, I also don't know the name
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/803737-cable-management/#findComment-10103057
https://linustechtips.com/topic/803737-cable-management/#findComment-10103079
