Having problems with connection to my router
Solved by The Owl,
Anything electronic in-between the router and device cAn cause issues, wireless landline phone's bases, etc... Use a app on one your phone's to see what wifi channel the networks around you are using, do it next to your router and then at each location the other devices are at. Once you know you can try to manually force your router to use a specific channel, it won't fix the issue forever but it will provide you a bit more stability.
