Hi,
I am building a pc for use at work, and would like some help with the specs. I am unsure of which processor/CPU combination to choose at the Intel line-up is extremely confusing at the moment. The PC has around a £750 budget, excluding the monitor (which I already have).
The computer will be used for mainly for the Adobe suite, particularly Photoshop, Illustrator, etc (but not video editing), outlook, and chrome with many tabs! It will need to be mid range to handle multiple applications smoothly.
Current decided specs:
Monitor: Asus 1440p PLS monitor.
Graphics Card: A 1050, or something similar around the £130 range.
Case: Preferably Mini/Micro ATX
RAM: 16gb, whichever is the cheapest available
Any suggestions for the CPU/Motherboard combination would be appreciated, thanks.
https://linustechtips.com/topic/803569-work-pc-build/
R5 1600/1500x should be around that price point. I am not entirely sure if i5 7500 (it has similar price but not overclockable) would be faster for Adobe. (I know an i7 is faster for that than R7). Also you should stay 8GB for now as getting another 8GB stick of RAM is easy like a piece of cake.
https://linustechtips.com/topic/803569-work-pc-build/#findComment-10101214
R5 1600 or a 7500
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/803569-work-pc-build/#findComment-10101231
Just now, TDCDigital said:
Wait until the etherium craze is over then buy the rx 580 with it's build and for a small bit more you can get a ssd
https://uk.pcpartpicker.com/list/bK7Pqk
It's a work PC, you don't always need an expensive card, a 1050 can video edit just fine.
lttstore.com
https://linustechtips.com/topic/803569-work-pc-build/#findComment-10101275
3 minutes ago, TB-303 said:
Hi, thanks for that. I forgot to mention, I will be getting an SSD, a lower end video card is fine for this build, just confused about Intel as their products are all over the place at the moment.
Should i go for i5/i7 or Xeon?
Amd ryzen 7 1700
https://linustechtips.com/topic/803569-work-pc-build/#findComment-10101304
https://www.pugetsystems.com/labs/articles/Photoshop-CC-2017-1-1-CPU-Comparison-Skylake-X-Kaby-Lake-X-Broadwell-E-Skylake-Ryzen-7-976/
If Photoshop is heavily used, then an i7-7700K is probably a better choice than an R7. I don't believe illustrator is multithreaded so an Intel core would likely offer better performance.
Not clear if storage needs to be included. So I left it out.
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  (£298.98 @ Aria PC)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£25.66 @ Novatech)
Motherboard: Asus - PRIME B250M-A Micro ATX LGA1151 Motherboard  (£69.84 @ Aria PC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  (£114.09 @ Ebuyer)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card  (£124.99 @ Overclockers.co.uk)
Case: Cooler Master - N200 MicroATX Mini Tower Case  (£51.47 @ Amazon UK)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£48.44 @ Ebuyer)
Total: £733.47
Generated by PCPartPicker 2017-07-07 04:37 BST+0100
https://linustechtips.com/topic/803569-work-pc-build/#findComment-10103897
