Very Small CPU Fan???
5 minutes ago, NovaMan01 said:
Im looking for a CPU fan that is under 1.8" for a Xbox 360 case build. Any suggestions?
fans are spec'ed out in metric. convert that ish
you can find them in any size though so don't worry
(edit) you can also just repin the fans that are already in the 360 to work on a motherboard
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10099442
1 minute ago, NovaMan01 said:
38.5 mm for a LGA 1511 socket
thick or wide.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10099448
45.72 mm for a LGA 1511 socket
you mean LGA 1151 right. so skylake or kabylake. fans that size are going to be pretty noisy. i think silverstone have all the sizes possible and imaginable on newegg
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10099450
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10099453
Just now, NovaMan01 said:
What do you mean
should it be 38mm in diameter or 38mm thick.
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10099459
https://www.newegg.ca/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=38mm+fan&N=-1&isNodeId=1
sorry it's newegg canada idk if that's what you need. you can also find them for cheaper in used parts stores but i don't know where you live.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10099460
Most of these are case fans
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10099463
Do you want the xbox original fans? You can probably find spare parts on ebay
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10101772
Are you looking for a fan or cooler?
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10112944
39 minutes ago, NovaMan01 said:
a cooler for a CPU in a tight build
I don't think it'd get any better than the NH-L9i at 37mm: https://pcpartpicker.com/product/xxphP6/noctua-cpu-cooler-nhl9i
https://linustechtips.com/topic/803388-very-small-cpu-fan/#findComment-10113236
