LAPTOP POWER ISSUES
By
BLACLLISTER01
in Troubleshooting
in Troubleshooting
Solved by Zando_,
Connect the HDD to the 3.0, since it'll benefit from the speed, and likely uses the most power. Then use the 2.0 for the mouse/cooling pad. Or get a powered USB 3.0 hub from Amazon and keep them plugged into that. Then you just set your laptop on the desk, plug in the one USB 3.0, and you're good to go.
Ryanwake ·
Posted in General Discussion1 -
1
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases0 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning16
play_circle_filled
Latest From ShortCircuit:
