Storage in 1TB drive "split"
Solved by AdamBGames,
23 minutes ago, TheHappyGoat said:
if what emosun doesnt work, try this.
go into cmd, then type diskpart
then when diskpart opens another cmd type, list disk, identify your disk
then type, select disk (your disk number)
then type list partition
identify the recovery partition
type select partition (partition number)
then type delete partition (if this brings up an error add override to the end)
then all partitions should be unallocated
then make a new volume with the first partition
then when that is done, right click the partition you just made and click extend partition, then extend it to the next partition, do this till you have all partitions together
