Some games, however, do come with premade gamepad configurations, so that I don't have to map each function individually. The problem is, these games usually don't allow any custom mapping, and they almost always get the axes wrong. For example, the game Dead Trigger will let you use your gamepad right away, without any options or configuration required. The game maps the left analog stick to move, just fine, but it maps up/down look to up/down on the right stick, and left/right look to the triggers?! And worse yet, the triggers are one combined axis, so this means that I am constantly spinning around in circles like a retarded chicken on a merry-go-round and shooting ammo non stop util it run's out unless I press and hold both triggers and asphalt 8 airborne works okay. (i copied it off a xda forum because i having same problems and no one replied to him)
Can you help? Thanks
The Asus UX305 has an Almighty Intel core M-5Y10 0.8GHZ, GPU Intel HD 5300 Windforce, SDD 120GB, Passively Cooled, 1920x1080 Matte Screen, An Fantastic ICEpower Audio Making my House Shake and Having more ports then a MacBook btw this not an advertisement.
https://linustechtips.com/topic/80314-controller-issue/
Most Controller enabled games are designed for the Xbox360. is this the controller you are currently using?
No Logitech F310 which supports Android.  http://www.pocketables.com/2012/05/guide-to-game-controllers-on-android.html
https://linustechtips.com/topic/80314-controller-issue/#findComment-1101129
there are programs out there that can allow third party controllers to emulate the xbox 360 controller. I did a quick google search and this program came up: x360ce.
It for my Android device.
https://linustechtips.com/topic/80314-controller-issue/#findComment-1101151
