Psu cable doesn't fit?
Go to solution Solved by kerradeph,
Yeah, you're just looking for a NEMA C13 plug which is what plugs into the PSU and whatever standard is used in Hong Kong.
So I was doing an itx build with the seasonic m12ii 520w psu and everything was going surprisingly well until I realized the cable from the psu to the wall doesn't fit locally... it came with a 2 flat 1 round male, but all I had was 3 flat female (Hong kong)...
So that left me with 2 options: buy a 3rd party cable or just cut and solder on a new male head that fits. I heard 3rd party cables aren't very good for the psu health, but then tbh a hand soldered cable isn't exactly stable anyway. So what should I do? Thx
https://linustechtips.com/topic/802904-psu-cable-doesnt-fit/
buy a third party i don't think it will really affect anything they are pretty standard. (unless the ground isn't really connected and is there only for show)
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/802904-psu-cable-doesnt-fit/#findComment-10093944
