Hello.My laptop seems to have an issue. It has a gtx740m and an i3-4010U. When I play games It usually runs smoothly but sometimes I have really low fps.The reason to that is that the computer sometimes uses intel graphics card instead of the nvidia one and I dont know how to fix it.
https://linustechtips.com/topic/802070-need-help/
Use are more suggestive title next time pls.
Which game deos the problem appear in? How do you know it uses the iGPU?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/802070-need-help/#findComment-10085142
3 minutes ago, Remember21ME said:
I play rocket league usually.Minecraft shows which gpu the computer uses while playing and thats how.
Using the NVIDIA panel software that should be installed on your laptop, or even the Intel Graphics panel, you should be able to set which one the PC will prioritize for 3D applications such as games. If you set it to this, and the games still don't use the NVIDIA one, it's very likely that the GPU is not being detected correctly.
https://linustechtips.com/topic/802070-need-help/#findComment-10085154
