https://linustechtips.com/topic/802017-will-this-build-work-together/
I'll get G4560 since it is cheaper and only a tiny bit slower.
Replace that PSU if you don't want to ruin your system. Looking at nz.pcpartpicker I found this: https://nz.pcpartpicker.com/product/R2mxFT/corsair-power-supply-cp9020103na
Desktop benching:
Just now, MarcosTacos said:
Thx so much Man
if you get a g4560 you might need a z270 mobo as the z170 mobos need a bios update to support the g4560.
