Pc won't boot
the fans will run but no display and led from keyboard not responding
already tried to switch ram and change slots all combination.
and i notice that after 10 seconds of powering up the system will shutdown (lights will turn off and fans) then it will quickly boot up again but still no display.
i've already tried 2 psu to test but both the same result.
https://linustechtips.com/topic/801754-need-help/
Might help.
Probably the motherboard. If you have  beep speaker plug it in and see if it beeps a pattern.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/801754-need-help/#findComment-10081695
13 minutes ago, Ranz said:
uhm the stop is only happening once.
i've even tried no ram and got no beeps but the stop after 10 sec still happening.
Even the power connectors (CPU, mobo, GPU, storage)
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/801754-need-help/#findComment-10081745
yes the first thing i do was unplug the hdd, the audio/usb connector coming from case and only use the 24pin and the 4pin of usb attach in motherboard.
already tried 2 psu. and different rams and different slot. even tried to remove cmos battery. and i am not getting any beep. and all test have the result of powering off then quickly starting again.
currently now i am trying to reseat and try different processor.
hope this work.
https://linustechtips.com/topic/801754-need-help/#findComment-10081751
hope this work.
It might be but CHECK the pins on the mobo
https://linustechtips.com/topic/801754-need-help/#findComment-10081760
1 minute ago, Ranz said:
you mean the cpu socket pins?
uhm there are too many and small pins is there any possible or easier way to check or to see which is wrong?
Yes shine a light on it and look from different angles if there is no bent pins it should be find but test with a different CPU
https://linustechtips.com/topic/801754-need-help/#findComment-10081781
i tried to see several times and even use a phone to see bigger but i can't see any bent pins
will try to replace processor.
https://linustechtips.com/topic/801754-need-help/#findComment-10081836
6 minutes ago, Ranz said:
After changing the processor still no display/beep but the shutdown after 10 sec and power up ddnt happen anymore.
Ok it's a faulty CPU return it asap and what CPU is it?
https://linustechtips.com/topic/801754-need-help/#findComment-10081877
Uhm okay here is some result
CPU - g4560
no beep at all and shutting down after 10 seconds and starts to power up but both do not have display or POST.
CPU - celeron g3900
i did not get any beep at first then i tried removing ram and then i did have a beep.
after it i tried to return the ram but still no display no beep.
and i tried to put some gpu as i was thinking this might be the same with my first issue
so i think asrock is some piece of shit. all of this item is still in warranty but for sure the store will always say that it has bent pins again and will void the warranty.
https://linustechtips.com/topic/801754-need-help/#findComment-10081900
You need to update the BIOS on that board to use Kaby Lake CPUs in it.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/801754-need-help/#findComment-10081909
2 minutes ago, Ranz said:
Actually it was working before and just got stuck for like 1 week of no use. i bought it kaby lake ready already.
Can you boot into your BIOS?
SPECS:
https://linustechtips.com/topic/801754-need-help/#findComment-10081930
48 minutes ago, Ranz said:
yes i can now use the pc but only with GPU present.
You need to update your bios that's it
https://linustechtips.com/topic/801754-need-help/#findComment-10082157
