Hey guys,
I´m looking into PSU´s in the 750 to 850 Watt range that feature 2x 8-pin ATX 12V CPU connectors, preferably Gold efficiency.
And finding a PSU with those connectors seems to be a pain.
However I found a few and wanted to ask you guys which one to buy.
Those are:
Cooler Master V750 Modular 80+ Gold 750W
Seasonic Prime 750W Modular 80+ Gold
Seasonic Prime 750W Modular 80+ Platinum
Seasonic Prime 850W Modular 80+ Gold
BitFenix Whisper M 850W Modular 80+ Gold
Feel free to recommend others :)
CPU: AMD Ryzen 9 5950X PBO GPU: Asus Strix RTX 3090 OC Mobo: Gigabyte X570 Aorus Master RAM: 32GB G.Skill Trident Z RGB 3600Mhz CL17
CPU Cooler: Corsair H150i Capillex Storage: Samsung 980 Pro and 970 Evo 1TB Samsung 860 EVO 1TB Crucial MX300 525GB WD Black 2TB PSU: Corsair HX1000 Case: Corsair 500D SE RGB 6x LL120
https://linustechtips.com/topic/801675-help-deciding-on-psu/
1 minute ago, racer243l said:
Hey guys,
Those are:
I have no experience with seasonic but the prime models appeal to me out of all of those listed, platinum is a bonus and i doubt you need more than 750w so i reccoment the platinum one
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10080884
1 minute ago, Vespertine said:
I'd go with the Seasonic Prime, whichever one is cheaper for you from the three.
Ironically the 850W one is the cheapest xD Thanks for your opinion :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10080886
PCPP says 543W (without OC obviously) so I guess you are right. But PSU´s with less then 750W rarely have the 2x CPU connectors. Thanks :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10080900
Its nice to have a little buffer, going for 650/750 isnt horrible, are there any adapters you can buy. surely theres something, or custom cables you can purchase. No worries :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10080909
3 minutes ago, Grim reaper 999 said:
How about Corsair RM 750 X
Doesn´t have two 8-pin ATX 12V CPU connectors and is pretty hard to get apperently
I think there are some, yes. But I´d like to have some headroom :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10080924
I believe theres a power supply by seasonic that has two cpu connectors but its a little expensive
https://pcpartpicker.com/product/CfXfrH/seasonic-power-supply-ss660xp2
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10080949
The ones I mentioned in my original post all have those connectors :) That´s why I wanted help deciding which one to buy :)
They are listed with 2x 4+4pin 12V ATX CPU power :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10080955
@racer243l  This is the prime 750W Gold, isnt this fine??
Yep, exactly what I need :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10080962
I personally choose the SeaSonic, even though i like the X series more than Prime series. Yeah go for the SeaSonic X 750W Gold or SeaSonic X at the same wattage
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10081028
Well the X Series are impossible to get here in Germany :( Only scetchy amazon market place seller has one. The 850W is cheaper so I might get that one :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10081239
Well them get the Prime that is rated in Gold, Platinum is better and if you have some money
My head on 2019 :
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10081331
Alright, thank you :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10081616
5 hours ago, racer243l said:
Hey guys,
Those are:
All of those are really good but what are you powering? If it's the 6700K system in your signature your RM550X is plenty, even for OC.
If you plan to SLI 1080 Tis then grab yourself an 850W unit, whichever is cheapest among those choices.
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10082032
It should power a X299 i7 7820x (patiently waiting to get shot xD) or Threadripper system this summer. SLI is a huge maybe :)
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10085554
Well if you're certain about SLI then an 850W should be your minimum. 1080 Tis use a lot of power when overclocked and in SLI so a 1000W unit might even be justified.
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10086683
Thinking back to GTX 670 days when I had SLI for a couple weeks I won´t do it again xD I will stay single card for now.
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10091008
I have a Seasonic Prime Gold 650W and I'm very happy with it. It's a great PSU!
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10091138
I will get the 850W Gold since it´s the cheapest right now. Hopefully it will be like this in 3 weeks when I order the parts xD
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10091145
Wait what? Since when?! I think i am getting either prime or X Series!
My head on 2019 :
https://linustechtips.com/topic/801675-help-deciding-on-psu/#findComment-10091378
