Basically the title. I'm looking for a good guide on overclocking ddr4 that works on skylake. What voltages are safe? Are temps something I should worry about? What should I use to test stability? Should I go for cas or clocks?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/801041-looking-for-ddr4-overclocking-guide/
IDK about others but,
Use memtest86 to test stability.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Buy a big padlock and place it on the ram?
Seriously though, just use XMP :D
Main Rig:-
Server:-
But what if my Ram is already running at 2133MHz and I want to go further, hence "overclocking".
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
In real world scenarios OCing your RAM will give you no noticeable increase in performance, sure you might be able to increase some benchmark numbers (things like AES decryption and archive extraction) but it won't make any difference to the things you do the majority of the time.
Use XMP (or whatever Ryzens equivalent is called) to set your RAM to its JEDEC profiles settings and that's it, you don't need to mess with anything else.
BTW if your RAM is running at 2133 then its likely not overclocked, obviously unless your bought 2133 RAM. 2133 is the default speed all DDR4 runs at so go into your UEFI and check you have XMP enabled.
Main Rig:-
Server:-
