As low as they can go. For me, the safe point is 85C on most of Intel's chips. I don't know what's considered "safe" for Ryzen.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/801030-i5-6500-temps/#findComment-10073896
There is no safe point on Intel chips, it will throttle if it exceeds 100C. But it won't damage.
Any safepoints are subjective. The only reason to keep the temps down, is leakage. So your power consumption goes up.
https://linustechtips.com/topic/801030-i5-6500-temps/#findComment-10073986
I know that, I'm stating what I would say is a "good" upper limit in the case of overclocking as an example, though this thread doesn't fit that.
https://linustechtips.com/topic/801030-i5-6500-temps/#findComment-10073995
longevity of the parts factor in as well, a cool cpu would  last longer than one constantly pushing +80c  and over
try to stay under 80c under load and you're golden
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/801030-i5-6500-temps/#findComment-10074000
This pervasive argument has never been proven, and never will be. Laptops run >85C on the chips most of the time during load and usually it's things like hard drives, broken displays or simply them being to slow that gets them replaced.
fml the 80C rule is even worse.
Well you can get a bit of a thermal runaway, where the increased temperature increases the load, which increases temperature ...etc.
And perhaps it will remain more stable at lower temps when you start overclocking. No guarantees though.
https://linustechtips.com/topic/801030-i5-6500-temps/#findComment-10074003
Agreed, which is why ...
 ... is the better choice.
https://linustechtips.com/topic/801030-i5-6500-temps/#findComment-10074023
