So my issue is that in obs I seem to be getting a pretty big frame drop that is really noticeable. I did have the problem until just recently. I haven't made any changes to my settings in a couple of months and it just started acting funny the other day. Later today i found out that don't even have to be streaming or recording to see the frame drop below the 60 fps I usually use. Also I only experience this with PC streaming if I use my capture card for console the problem goes away. Also idk if this matters but when I minimize the game to do something else obs is goes back to 60 fps but then goes right back to dropping as soon as I get the game back up.
Just found out that if play in border less window the it gets a little better still experience a little frame drop but not nearly as bad
https://linustechtips.com/topic/800788-problems-with-obs/
computer specs? and what temperatures are you getting under load?
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/800788-problems-with-obs/#findComment-10071284
17 minutes ago, fixitnow said:
Is the CPU or GPU thermal throttling? Make sure that you don't have an FPS limiter on.
Not experiencing any thermal throttling also game runs fine it is only obs that acts weird i can play the game and get a constant 70 fps or above but obs will only get say its getting around 37 or so
https://linustechtips.com/topic/800788-problems-with-obs/#findComment-10071326
try using a temperature and clockspeed logger which would confirm or eliminate any thermal throttling, the temperature might be the same, but clockspeeds can vary
Personal Rig Specs
https://linustechtips.com/topic/800788-problems-with-obs/#findComment-10071336
I'm not so sure its a problem with my computer as I think its a problem with obs itself. My game runs just fine with or without obs running, obs is the only thing where I see a problem
https://linustechtips.com/topic/800788-problems-with-obs/#findComment-10071344
Also I think it is important for me to note because I don't think I made this clear enough is that these setting and parts have worked fine for streaming and recording for the past year only this week did obs start to act weird. I didn't change any setting or hardware. It is not a new build or like I Swaped a part out and it stopped working or I changed some setting in obs it. It just one day it was working fine and the next it wasn't
https://linustechtips.com/topic/800788-problems-with-obs/#findComment-10071382
use ddu to clean out the display drivers and reinstall to see if that fixes the issue, also try to reinstall OBS
Personal Rig Specs
https://linustechtips.com/topic/800788-problems-with-obs/#findComment-10071387
