Hey guys. I have a very unique monitor setup and I'm trying to set my wallpaper to be a certain way but its not working correctly.
This is my monitor / tv layout.
and this is what it looks like in real life.
In short, I'm trying to get this picture to span across the 3 1080p (1920x1080) monitors. BUT HERE COMES THE HARD PART.ItBmAFN.jpg On the TV, which is 4k (3840x2160) I want the picture that is already on the TV. (can't find the source picture sorry)
Here's the problem. I can set this up in windows but every time I get the picture I want on the 1080p monitors to span, it won't. Unless all monitors are using the same picture. So it won't span unless it also spans across my TV, which looks hideous.
Can anyone help me out here? Thanks.
https://linustechtips.com/topic/800675-wallpaper-help/
You'd probably have to get third party software for this.
I'd recommend DisplayFusion, though I got it in a bundle, and I'm not sure what the price of that is right now.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/800675-wallpaper-help/#findComment-10070263
45 minutes ago, Sierra Fox said:
you can do it in photoshop. hit printscreen on your keyboard and paste it into photoshop. this will show the offset of all monitors against each other then cut the wallpaper into 3 1920x1080 and position them over the top of the windows for each monitor and then save it and set as wallpaper.
I believe Sierra's correct, you'll need to merge all the images into one super-collage with each screen in the proper position.
https://linustechtips.com/topic/800675-wallpaper-help/#findComment-10070826
