It looks like more of a general purpose/work monitor. An ideal gaming monitor would be 1080p. It'll perform just fine, it's just that being 1366x768 60Hz, it won't be as snappy as a 1080p 144Hz monitor. But, if you're gaming on a budget, it should be just fine.
https://linustechtips.com/topic/800218-aoc-e943fws-for-gaiming/#findComment-10065715
7 minutes ago, julian9855 said:
aoc e943fws how does it preformese in gaiming pls help
it's a generic unimpressive bottom line display... i don't understand your question?
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/800218-aoc-e943fws-for-gaiming/#findComment-10065718
35 minutes ago, julian9855 said:
It is a pretty basic monitor, resolution is crap, response time is kinda meh. Panel and image is probably fine, just nothing to call home about.
I mean anythings a gaming monitor if you play games on it.
and for the super lazy TLDR: it's a piece of shit
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/800218-aoc-e943fws-for-gaiming/#findComment-10065787
