@Sbuqaarah Hi! :D
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/799758-gtx-1080ti-problem/#findComment-10060638
7 minutes ago, Sbuqaarah said:
Hello Everybody
I have a problem with my gtx 1080ti where i have a moniter is 1080p and 144 hz when i run overwatch and any other game i get a 100fps max
any idea on how to fix it ?
Thanks
Well, first of all have you checked whether you set your panel to 144hz in Nvidia control panel?
Second, for overwatch if you used the optimize option in Nvidia geforce experience, make sure to go to set the rendering to 100% if you want more fps
other than that, I've no idea what other games you tested the card on. extra feedback will be helpful
as well to make sure that vsync is off.
https://linustechtips.com/topic/799758-gtx-1080ti-problem/#findComment-10060653
in the nvidia panel its set to 1920X1080 144hz and im using DVI dose the connector affect ?
https://linustechtips.com/topic/799758-gtx-1080ti-problem/#findComment-10060659
Have you checked if Render Scale in overwatch is set to 100%? sometimes the auto optimize from Nvidia geforce experience pushes it further, which imo doesnt make much difference other than sacrificing some FPS for extra scaling, which on a 1080p didnt make much difference in my experience
https://linustechtips.com/topic/799758-gtx-1080ti-problem/#findComment-10060674
Yah it worked thanks
https://linustechtips.com/topic/799758-gtx-1080ti-problem/#findComment-10060688
