Hey guys. So trying upgrade my current potato that is a old Dual Core E5700 to something newer. Right now i want something budget oriented and from what i found out the i3 7100 and the  Intel G4600 have the same similar performance standards... only one been slightly cheaper. So now i'm undecided what motheboard to pick. I want something that can be a little future proof if i want to upgrade from that G4600 to an I5 down the lane. Right now i dont need a ATX mb since i only use one GTX 1050ti and probably wont upgrade the GPU in the nearest future so i'd stick to the Micro-ATX side. I want something that is reliable, with good audio and some decent expandability. I dont need USB 3.0 since none of my devices that i own have that sort of ports. My location is Romania and my budget for this is probably 400 Euro. That's for the CPU/MB/RAM. My local online shopping stores are PCGARAGE and EMAG. Any suggestions?
https://linustechtips.com/topic/799753-planning-advice/
