Hola,
I am going to build an extremely budget build for my office. I am not going to run GTA 5 on 4K, it's just for a few office purposes.
Here are the parts I've chosen for the build,
AMD fx-6300
4 Gigs of RAM
nvidia GT-730
My doubt here is, will there be bottlenecking, If yes then which CPU+GPU combo is best for the build. Please suggest
Thank you
https://linustechtips.com/topic/799680-suggestions-for-my-build/
Do not get FX CPU nowadays even for budget build, do you have $800 there?
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
Also, for just office use, I'd drop the GPU completely, adds expense that you could other wise put into a SSD or better CPU, they will have much more effect on a machine like this.
Samuel Edwards
- IT Engineer and Media Producer -
Religious theology diploma and over half a dozen certificates in Advanced Computing and IT.
Current Project:   Mineral Oil Cooled PC
Just trying to be friendly and help where I can. Have yourself a great day!
Use @SamuelJE for friendly tech help :)
Main PC - "The Genesis"
Mobo   -   Gigabyte GA-H170-Gaming 3
CPU     -   intel i5-6600K 4Ghz on water
GPU     -   MSI GTX970 "Red Dragon"
Case    -   Zalman Z11 Plus (Custom RGB Obviously, It's 2017 bro...)
OSD     -   Crucial 275GB M.2 SSD
SSD     -   Crucial 250GB SATA SSD
HDD    -    4TB WD Green x 2
Disp     -   LG ultra wide Gaming Monitor
Secondary PC - "Jonah"   (Mineral oil PC)
Mobo   -   Gigabyte GA-B250-DH1
CPU     -   intel i5-7500 Under Oil
GPU     -   Nvidia GTX 660 (Favorite and first ever GPU)
Case    -   A Fish Tank W/ Custom Engineered Mounting System (Custom RGB Obviously, It's 2017 bro...)
HDD    -    2TB WD Green
The GPU is for little photoshop and video rendering purposes. Otherwise I'd have dropped it completely
Ah I see. In that case I'd say the combo matches pretty well. For $500 you'll be getting a pretty nice system :)
Best of luck.
Samuel Edwards
HDD    -    2TB WD Green
PCPartPicker part list: https://pcpartpicker.com/list/JtC4TH
Price breakdown by merchant: https://pcpartpicker.com/list/JtC4TH/by_merchant/
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($74.89 @ B&H)
Motherboard: MSI - B250M BAZOOKA Micro ATX LGA1151 Motherboard  ($72.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws 4 series 8GB (2 x 4GB) DDR4-2400 Memory  ($59.92 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB FTW GAMING ACX 3.0 Video Card  ($160.49 @ B&H)
Case: BitFenix - Comrade ATX Mid Tower Case  ($29.99 @ NCIX US)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Total: $496.71
Generated by PCPartPicker 2017-06-28 00:12 EDT-0400
lttstore.com
20 minutes ago, itassistors said:
My budget is around $500 and not more than that.
As I quoted, "it's an extremer budget build.." :D
at 500 usd, you can get a locked Haswell i5, 8gb ram and 1050ti set up.
Desktop benching:
Total: $496.71
If OP really isn't gaming, OP doesn't need a GPU
SRRY its more
CPU: Intel - Core i5-7500 3.4GHz Quad-Core Processor  ($187.89 @ OutletPC)
Motherboard: Asus - PRIME B250M-A Micro ATX LGA1151 Motherboard  ($67.98 @ Newegg)
Memory: ADATA - XPG Z1 16GB (2 x 8GB) DDR4-2400 Memory  ($99.99 @ NCIX US)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($77.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($66.89 @ OutletPC)
Case: Rosewill - FBM-01 MicroATX Mini Tower Case  ($24.99 @ Amazon)
Power Supply: SeaSonic - 300W 80+ Bronze Certified ATX Power Supply  ($36.69 @ SuperBiiz)
Total: $562.32
Generated by PCPartPicker 2017-06-28 00:21 EDT-0400
Do you consider used parts like i do?
My head on 2019 :
