Long Range Wireless Data Transmission
There won't be an easy way to do this. Firstly, for 90 miles, that's too far away without towers. Since the earth has this nasty problem if being round the curvature of the earth gets in the way at long distance. To reach 140+km (90mi) you would need a tower that is about 1.25km tall. That would be a bit less than 2.5 CN towers... You may want to get a building permit from the municipality first.
Since you'd have to construct the tallest tower ever built by man... That might not be the most practical plan
Alternatively you could look at radio transmission options that involve bouncing your signal off of earth's ionosphere but this is no trivial task either... Though it would be easier than accomplishing the greatest engineering feat in the history of your species. But this involves buying the proper equipment and actually learning how radio works.
Bonus Info: While usually seen as a tourist attraction, the CN tower is actually covered with communications antennas, it broadcasts television, radio, it's a microwave communications link for telecommunications and re-broadcasts radio signals for multiple municipal services such as police, fire, or transit.
