Hello my Friends,
     So I was confused about water being inside the aio. Like I know that distilled water is a good choice of water to put in the aio, but I was wondering how the water is actually put inside the aio. So if anyone can tell me that would be great.
        Adios Amigos, A Silly Goose
https://linustechtips.com/topic/799269-water/
2 minutes ago, JermaTheGoose said:
Hello my Friends,
I would assume it was put in the AIO before it was seal ...
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/799269-water/#findComment-10055065
11 minutes ago, JermaTheGoose said:
Hello my Friends,
AIO's come pre-filled from the manufacturer. You don't need to fill them yourself.
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/799269-water/#findComment-10055082
They put distilled water (usually) inside before sealing the end of the hoses
Desktop benching:
https://linustechtips.com/topic/799269-water/#findComment-10055099
This distilled water also has some additives in it. Like the ones you put in custom loops.
For example
-corrosion prohibitor
-anti biotic stuff
etc.
But yeha dont worry. you will not have to fill or change annything
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/799269-water/#findComment-10055228
