a few networking questions
question number 1:
right now I have this Wireless adapter - http://www.newegg.com/Product/Product.aspx?Item=N82E16833127272 ... and it really doesn't get the job done, it throttles my 8 mb/s internet down to 2 or 3 mb/ps and when my friend came over with his PCI-E card and I tried it out, I was getting up to 7 or 8 mb/s like i should be... would it be more worthwhile to get a PCI-E card? if so, which one (please nothing too extreme in price).
Question number 2:
My router is probable about 26 feet from my router, would it be better to run a CAT-5E cable from my modem, down into my basement then back up into my floor to my computer instead of using wireless?
Intel i5-3570K @ 4.1GHz  • XSPC Raystorm • FrozenQ 250mm Liquid Fusion • 8GB DDR3 1600 (PC3 12800) • Gigabyte GA-Z77X-UD3H
Gigabyte GTX 970 G1 Gaming 4GB • Seagate Barracuda 1TB + Intel 730 Series 240GB • ASTRO A40 Audio Solution • D-Link N-150
https://linustechtips.com/topic/79858-a-few-networking-questions/
Yes Ethernet all the way!. lower ping, stable connection.
Ethernet has a signal limit of around  100 meters so you are fine :P
okay and should I go CAT-5E or CAT-6
From a home user there is really no difference, go with the good old Cat 5E
okay thanks, and you're sure that about 50ft of cable won't screw up the connection?
15-16 meters of Ethernet is well within the 100meter spec of Ethernet. don't worry :)
(328ft = 100m)
wow, okay so there won't be any latency impact?
Its electrical signals, Part of the Electro-Magnetic Spectrum so it travels at the speed of light (299 792 458 metres per second). so you wouldn't notice between 1-100M anyway haha :P
oh wow haha, also, if I were to run it the same route my Cable wire is run, would that affect it?
No
okay, and I have the tools to make the Cat-5E myself, like to cut the wire and put the connector on and stuff, would it be better to do it this way or buy it premade
Thanks for the help
