I need Help!
Go to solution Solved by JakeNTech,
Just now, alexlenadi said:
well I cant buy anything else...
I still need to know if it will fit physically corectly
Google the card and look for dimensions and then take a ruler and messure your case. I still don't reccomend buying a budget card. GO to a shop like CEX and buy a 750Ti, or 550ti like I did
So, I am planning to buy a  MSI GT 730 2GB v2 128 but I don't know if it will fit in my pc!
The motherboard port allows it to enter(the port is compatible with the gpu's) but I want to know if it will fit physically!
H110M-CS (motherboard)
Don't get the 730.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047425
Why tho? Pls tell me why.
It's awful.
زندگی از چراغ
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047432
Unless its a GTX all GT cards are practically the same and they are all underpowered for what they are, its a budget card, you would be better of spending the money on a second had GPU. THe only time I would recommend a GT card is for a HTPC or juts to have one lying around to diagnose computers that have no igpu. Most GT cards are the same as integrated graphics.
Have you tried turning it off and on again?
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047447
I know but I don't have enough budget and in my country the prices are a bit high
and the gt 730 is enough for me
Then look on the used market for a better option like the 750 or 750Ti.
زندگی از چراغ
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047453
well for now the gt 730 is better than my integrated graphics I have now...
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047462
Even so you would still be wasting your money on a budget card:
Low End Video Cards Rant - Are they still terrible
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047477
Then use your IGPU at the moment until you have enough to spend on something way better.
زندگی از چراغ
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047490
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047493
Defo go with a good used card, plenty around, the 730 is awful, I haven't read one good thing about it.  It even looks stupid :/
CPU: Intel Core i7-7700k @ 4.8ghz | Motherboard: GIGABYTE Gaming Z270XP-SLI | Graphics Card: AORUS GeForce® GTX 1080 Ti | RAM: 16GB Corsair Vengeance 3200mz |Storage: 1 x Samsung 250GB 960 Evo PCIe NVMe | 2 x Seagate 1TB [raid1] - overflow stuff | 2 x Samsung 850 EVO 500gb [raid0] - games | PSU: Corsair CX750M | Case: Corsair 400C | Cooling: Kraken x62 AIO | 3 x Corsair AF140 | 1x Noctua  NF-F12 | SoundSoundblaster Zx through  KRK Rokit G5 monitors
To be updated... when I get time
https://linustechtips.com/topic/798571-i-need-help/#findComment-10047574
2 hours ago, alexlenadi said:
I don't trust used parts...
got scammed once...
Did you test it and did you ask what it was used for how, long it was used for because you could get screwed over by not asking that
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/798571-i-need-help/#findComment-10048040
