4 hours ago, razor007 said:
Hi guys...
I hv a pc case side panel with glass and i want to do mod so can somebody plz tell me any idea for the mod??
What are you trying to do replace the original plastic side panel with a glass one?
If so I have a general information on installing a glass panel under the Window Mod section:
https://linustechtips.com/topic/798469-side-panel-mod/#findComment-10047579
