Hi so I recently decided to try something a little silly - a 3.7GHz overclock on my Ryzen 1600 and a significant undervolt (I think -0.9V from a default 1.4-something). I was pretty sure it wouldn't work but I decided to try it anyway, and now my computer wont POST at all - just gets stuck in an endless loop of starting and restarting. I tried clearing the CMOs, and removing the BIOS battery, but I still have the same problem. Is it possible to irreparably damage components by undervolting? Help would be greatly appreciated - thanks.
Edited by Spiffo
https://linustechtips.com/topic/798034-resolved-undervolted-too-much-no-post/
4 minutes ago, Lazaro said:
disconnect from the wall/clear CMOS remove bios battery and see if your motherboard has any other form of resting settings.
Thanks for your reply. I had already tried clearing CMOS and removing battery with computer unplugged - but not at the same time. Now it boots, Thanks!!
