Anyone having problems with Corsair link not showing fan speeds when you wake you pc from sleep mode? If I restart it all comes back but anytime I wake it up from sleep the software displays nothing and changing setting doesn't work.
CORSAIR C70 - MSI Z77A-GD65 - I5-3570K - GSKILLS TRIDENT X 8GB 2400 - CORSAIR H100I - SEASONIC X760 - GIGABYTE GTX670OC
https://linustechtips.com/topic/7980-corsair-link-help/
sleepmodes are worthless anyways .
i can't say it often enough to people with a desktop PC.
just leave sleepmodes off.
and use the power on/off on the motherboard/desktop.
if you really must have sleepmode and the corsair link problem to be fixed. .
i suggest you check your motherboard website for support or Bios update (if the bios update info seems to indicate a problem fix)
and check the corsair website for the latest drivers/support.
https://linustechtips.com/topic/7980-corsair-link-help/#findComment-89876
