Hello!
I'm looking for the cheapest possible way of setting up a security camera system and was wondering if I could do it with the hardware I already have lying around: 2 old android phones and 2 raspberry pi's.
I was hoping that I could set up the old android phones as IP cameras and then use a raspberry pi to record the video feeds directly onto external storage / NAS drive.
After doing some research I haven't found an easy way to do this but I'm sure it's possible, any suggestions on how it can be done?
I'll be sure to update this post if I find a solution! Thanks in advance if you have any advice :)
P.S Linus this would make a good video maybe? :')
https://linustechtips.com/topic/797934-diy-security-camera-system/
I have played around with the idea in the past; download a local streaming app to the phone, connect to wifi, open video stream in favorite browser (not sure if vlc etc. work).
Now you have a live feed on the pc/pi, only need to capture it. If vlc opens it you could record it directly as well.
yeah this is a good way to go about it, send a video stream from the phones to vlc player running on the Pis and save it to a local drive or back out of the Pi to a SMB mount
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
