I'm trying to create a script that will download and run a file, then kill it once it's done. My goal is to update runtimes (java, flash, etc) in one swift shot.
The issue i'm running into is any script I make (powershell) runs fine on the local system, but taking the script to any other machine throws "cannot be loaded because running scripts is disabled on this system.".
I can run "set-executionpolicy unrestricted" on a given machine, but I need everything to be a one shot item; is there a solution for this?
This is what my script looks like
If (-NOT ([Security.Principal.WindowsPrincipal][Security.Principal.WindowsIdentity]::GetCurrent()).IsInRole([Security.Principal.WindowsBuiltInRole] "Administrator"))
$arguments = "& '" + $myinvocation.mycommand.definition + "'"
Start-Process powershell -Verb runAs -ArgumentList $arguments
Break
wget https://drive.google.com/uc?export=download"&"id=0B23KvKA052gSU0dJQ3Azd2dQblU -outFile C:\Users\Public\Downloads\updater.exe
start-sleep -Seconds 5
start C:\Users\Public\Downloads\updater.exe
start-sleep -seconds 15
Stop-Process -processname Ninite
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/797862-scripting-help/
Two things...
1. Make sure there's not a group policy setting blocking scripts from being run.
2. Edit your post to remove formatting so night theme users can read your post without highlighting the text.
https://linustechtips.com/topic/797862-scripting-help/#findComment-10041229
18 hours ago, TheKDub said:
Two things...
1. Running the script on any machine results in the same result, despite settings/group policy.
2. I use night theme and can see it just fine, but I'll remove whatever formatting it had.
https://linustechtips.com/topic/797862-scripting-help/#findComment-10044195
