Hey, im building this PC https://pcpartpicker.com/list/yHGfLD and then realized i needed a Wireless Network adapter. I want a PCI adapter over an USB one. I dont know much about networking but my internet is not super amazing so I dont know if I can cheap out on this or get a good one. Any suggestions on what adapter to get? Thanks for reading.
https://linustechtips.com/topic/797829-wireless-network-adapter/
1. Do you mean PCIe?
2. What connection standard are you using? a/b/g/n/AC/AD?
Just now, NCIX Lampy said:
I don't think you could get AC speeds if you want it for $30
Lowest you can get is around $45 on Newegg https://www.newegg.com/Product/Product.aspx?Item=N82E16833166124&ignorebbr=1&cm_re=wifi_card_for_desktop-_-33-166-124-_-Product
Oh dang thats expensive. What am I giving up if i dont get one thats supports AC speeds?
oh, never mind sorry about that, search filters messed up
here's one
https://www.newegg.com/Product/Product.aspx?Item=N82E16833320333&ignorebbr=1&cm_re=wifi-_-33-320-333-_-Product
It's not within range, but it's what I would consider close enough
4 minutes ago, NCIX Lampy said:
Ok, looking at this picture from that page
I dont get near those speeds at all when i do a speed test. Let me do one and post the results.
FireShot Capture 3 - ASUS PCE-AC55BT B1 AC1200 Dual-B_ - https___www.newegg.com_Product_Product.aspx.png
It would be something to do with your router settings then. You've stated that it says AC, that means your router can use the AC standard.
Maybe, i just dont want to get an expensive adapter when i really dont need it.
FireShot Capture 4 - Speedtest by Ookla - The Global _ - http___beta.speedtest.net_result_6402031659.png
Personally I would spend the extra $5, but if you're really not interested then just go for the n standard.
Well thank you for your help and suggestions. Im going to wait to save some more money to buy a wifi adapter.
