Nevermore.
It should. Do you have a cable to try it with?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/797686-poe-max-distance/#findComment-10039276
3 hours ago, brwainer said:
I've seen some really long ethernet runs, up to 400 feet, and normally you see issues with data integrity before the voltage drop becomes an issue with powering the device.
Yea, but going over the standard max distance while running passive PoE interduces safety issues, especially with shotty hardware.
https://linustechtips.com/topic/797686-poe-max-distance/#findComment-10041105
I wasn't talking about passive POE, we only use active POE with our cameras and APs at work, and our switches output 52V instead of 48V to help with the voltage drop. Passive POE, since you are starting at 24V, would have much greater issues with voltage drop over long distances.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/797686-poe-max-distance/#findComment-10042104
