Hello,
I'm planning a new build and I was thinking of the airflow for the Corsair Crystal 570X.
Want some advice on cooling.
So I'm going to be using the 3 120mm SP120 RGBs for intake at the front and an additional 2 SP120 RGBs for top and 1 for rear set for exhaust.
Because I'm going to be using a 360 rad, its going to be mounted at the front.
My first concern is that I've heard here and there these Corsair fans suck for radiator cooling. Would a push/pull for the rad help the airflow? If so, would it be okay to use the 3 pull performance fans with higher RPM?
Second concern is related to this - so the radiator is obviously going to cause some resistance for the intake. Assuming I don't use push/pull there are 3 fans for intake and 3 fans for exhaust, there will be negative pressure, because of the radiator. Am I right?
I know I'm oversimplifying things but I just want to think this through and I could really use a protip.
https://linustechtips.com/topic/797610-radiator-placement-airflow-question/
Probably slight neg pressure. I'd go for high positive pressure on this case because of all the gaps between panels.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
Yeah, I was thinking I might just reduce it to 2 fans for exhaust but that would reduce overall airflow.
Grab 3 Noctua NF-A12x15s and put them in a pull configuration on your radiator. If you don't mind the look of the fans and have the money, then grab 6 and put them in push/pull. Then grab 2 or 3 of the NF-S12B's and slap them on your exhaust slots depending on whether you went with pull or push/pull.
I would go for different fans but I feel like its a waste of money to use the crystal 570x and not use rgb fans, I'm basically buying it for it's aesthetic. I might just use those fans for pull on my radiator and the SP120 for push. Thanks for the advice xD
