Sony vegas render bug
Go to solution Solved by fizzlesticks,
Try opening task manager, right click the process in the processes tab (not applications) and go to set affinity then uncheck one or two of the cores.
Hey guys!
Ive got a problem using sony vegas pro 12,
when i am trying to render a video which is longer than one minute
it will stop around 9%, a error pops up and will say that sony vegas is using to mutch CPU space
how can i lower the CPU / GPU use of sony vegas while rendering?
https://linustechtips.com/topic/79746-sony-vegas-render-bug/
