Laser AIO Printer
Go to solution Solved by Loot,
go with the
Samsung SL-M2070FW Xpress
http://www.egprices.com/en/product/samsung-sl-m2070fw-xpress-20ppm-mono-multifunction-laser-printer-b-tech
I do like hp printers but the smaller ones (m100 series) are shit
i'm looking for a good Laser AIO printer which is a good bang for my buck and has wireless connectivity and doesn't have any major flaws
could you guys help ?
i live in Egypt btw so best if the printer can be found here
http://www.egprices.com/en/category/computers/printers
https://linustechtips.com/topic/796920-laser-aio-printer/
Do you want a color or black and white printer?
Budget?
https://linustechtips.com/topic/796920-laser-aio-printer/#findComment-10030821
11 hours ago, Loot said:
go with the
okay thank you but in the supported os list it doesn't have win 10 is it going to work or not
https://linustechtips.com/topic/796920-laser-aio-printer/#findComment-10036338
just checked the website and installed the samsung  driver on win 10 so shouldnt be an issue .. worst case scenario you can print anything from your phone
the latest driver from Samsung website:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=6640351&CDCttType=DR&ModelType=C&ModelName=SL-M2070FW/XAA&VPath=DR/201611/20161118111243355/M2070_Series_WIN_Printer_V3.13.12.05.20_CDV1.25.zip
https://linustechtips.com/topic/796920-laser-aio-printer/#findComment-10036772
i can't thank you enough but i was wondering what makes this one so much cheaper besides the lack of wireless connectivity ?
http://www.egprices.com/en/product/samsung-scx-3405f-multifunction-laser-printer-micro-labs
https://linustechtips.com/topic/796920-laser-aio-printer/#findComment-10040375
The m2070 is a true multi function... has better scanning options/google cloud print/wireless while the scx-3405 is basically a fax than you can happen to scan with.
https://linustechtips.com/topic/796920-laser-aio-printer/#findComment-10041003
