Problem: I currently have 2 monitors that only have 1 HDMI and 1 VGA, which are usually hooked up to my pc. I have a Nintendo Switch and a GameCube I would like to be able to play. However, my monitors do not have any audio out.
Question: I am looking for a video hub that has AUX out audio, and, in a perfect world,  2 HDMI and 1 RCA in with 1 HDMI out and audio out. Does anyone know where I could buy such a device?
Something with 3 HDMI inputs and 1 HDMI output with and aux would also work.
https://linustechtips.com/topic/796304-audiovideo-hub/
I don't know there is one but you have to use a bunch of dongles to get it to work then it would be expensive
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/796304-audiovideo-hub/#findComment-10023878
You could try looking for a KVM Switch... not sure if you need to access multiple devices from 1 keyboard/mouse/monitor, but the switch will have Audio in/outs.  Either way, HDMI can carry audio streams, so you could use an HDMI HUB and an audio splitter for the RCA?
https://linustechtips.com/topic/796304-audiovideo-hub/#findComment-10024051
