I just got a new monitor 144hz with G-Sync.  I wanted to experience higher refresh rates.  I was playing Doom with in-game V-Sync off.  When V-Sync is off the games FPS goes up to 200 which is not stable.  I managed to make it stable by using riva tuner and capping it to 144hz.  Here's what I need to know.  Does capping the frame rate using riva tuner cause input lag?  What's the best way to cap frame rate without any losing any input lag.
https://linustechtips.com/topic/795578-frame-rate-capping/
well running 200 fps is actually the lowest possible input lag you can get, even though your monitor is only 144hz. but if you want to leave g-sync operational cap framerates to 142-143fps with either rivatuner or in-game frame limiter. this way if fps spikes it won't accidentally disable g-sync. alternatively you can turn on fast sync which is in the NVIDIA settings, which helps with tearing anomalies when fps is higher than refresh rate
https://linustechtips.com/topic/795578-frame-rate-capping/#findComment-10015641
you can cap it at 144hz with riva tuner or you can use Vsync, both will have the same effect...i usually use both
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/795578-frame-rate-capping/#findComment-10015760
