question about led light strips
Go to solution Solved by W-L,
Just now, Lilninjsways said:
yes it's rolls of rgb leds do I need to send a link?
I'm pretty sure they will be the standard smd5050 type as that is the most relevant. As for syncing all the rolls together since you are adding more than what the original controller will be designed for, unless it's one of the high amperage units, your going to require an amplifier unit that will let you inject 12V power mid way to give enough power for the extra length.
https://www.amazon.com/SUPERNIGHT-Repeater-Signal-Amplifier-Strip/dp/B00E4JQDKE/ref=sr_1_1?ie=UTF8&qid=1497750993&sr=8-1
I finally just got my package of led light strips.... my father has been wanting to do a man cave in his garage... he has been gone for two weeks and me and my 3 friends have been working hard for when he gets back tomorrow he will have a whole new garage for his gaming nerdy fun stuff! so I realized after I ordered that the led light strips were to little and bought more and it measures perfectly but it comes wit 2 strips is there a way that you can hook them up together and it basically syncs or no?
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
https://linustechtips.com/topic/794860-question-about-led-light-strips/
Are they rolls of RGB LED's if so it needs to go through to the controller which also need to be able to sustain the extra load from two extra strips of LED's.
-Moved to Hobby Electronics-
RAM: 32gb ddr3
okay thanks!
RAM: 32gb ddr3
okay thanks!
Just make sure you do this at the end of the first strip and have it so you parallel ( or use a splitter) off the amplifier with large enough 12V power supply for the two extra rolls of LED.
