So basically my problem is i have 50-80fps and it feels like i have max of 20fps..
and i'm running Freesync also
I know it's an early alpha game but it shouldn't lag like this
These are my ingame settings https://pastebin.com/raw/1XH4Z0N4
PC Specs are: i7-4790k 4ghz, r9 390 8gb, 16gb ram
https://linustechtips.com/topic/794630-low-fps-pubg/
maybe lower the settings ?
My Rig : https://pcpartpicker.com/list/MTBd2R
My VM Server : https://pcpartpicker.com/list/rPR6gL
My Backup Server : https://pcpartpicker.com/list/cRQYYr
My Storage Server : https://pcpartpicker.com/list/tzzR9W
My Router : https://pcpartpicker.com/list/bMPN4C
My Laptop : Lenovo Z575 with 6 GB RAM (1866 MHz), Crucial MX300 525 GB & Western Digital 2 TB (Removed optical drive)
https://linustechtips.com/topic/794630-low-fps-pubg/#findComment-10004437
Change your settings from low to medium as that makes it more CPU heavy, also put post processing very low.
Change textures to medium.
If you have a computer I would recommend downloading MSI afterburner and seeing your GPU temps
as it might be throttling.
That should help, at least that's what helped me.
https://linustechtips.com/topic/794630-low-fps-pubg/#findComment-10004456
Maybe have more balance between the settings? I have heard something to do with screen scaling and fps issues. I don't specifically remember what, apologies.
https://linustechtips.com/topic/794630-low-fps-pubg/#findComment-10004459
max temps gpu reached was 72c/161F and around the same for cpu so..
https://linustechtips.com/topic/794630-low-fps-pubg/#findComment-10004594
i have about max 50+ and min 40+ on a titan x maxwell oc'ed to 1.4ghz. everything's maxed out except the foliage that's set to very low as they say that doesn't make a huge difference after some updates. had to reduce the screen scale to 100 as 120 dropped like 10+ frames.
https://linustechtips.com/topic/794630-low-fps-pubg/#findComment-10012582
