I am new to this whole mining thing and understand that there are risks with the hardware when doing so. I am using nicehash with my EVGA 1080 hybrid.
I am getting temps of 50-58 degrees under load (completely fine for the card) but just wanted to make sure that I am not going to damage anything instantly. I know that if you mine for a few years that it could damage the card, but I am sure that once the 11 series comes out I will get something new anyways.
https://linustechtips.com/topic/794491-how-likely-is-damage/
you'll be fine
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/794491-how-likely-is-damage/#findComment-10003040
It causes no more damage to the cards than any other compute intensive task over a similar time frame. So 8 hours of mining is like an 8 hour gaming marathon.
https://linustechtips.com/topic/794491-how-likely-is-damage/#findComment-10003041
no damage at all, especially with those chilly temps.
you could run your card like that for 20 years and it would be completely fine, assuming the fans hadn't died by then.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/794491-how-likely-is-damage/#findComment-10003050
