Hi, this is my first post on this forum. And i know that 9999+ posts of this already exists on the internet. But none of it have worked for me.
I want to overclock my cpu to 4.4ghz, but i'm getting 80-85c on the cpu. I have tried to tweak my bios as much as i possible can, but no results.
I have made a little video to show my problem: https://www.youtube.com/watch?v=n0oz0Rf-iFY&feature=youtu.be
I7-3770K
GigaByte Z77X-D3H - Modded Bios
Gtx 980 g1 gaming
16 gb ram 1600mhz & 9cas kingston ram
Samsung SDD EVO 840 -128 GB
1TB HDD
Seagate FireCuda SSHD 2TB
Asus Xonar DX 7.1 - Modded
HAF X NVIDIA EDITION
Sorry for the guys checking this post early, i posted it as a error too early
https://linustechtips.com/topic/794144-bad-cpu-temp-for-liquid-cooling/
Its a 3770k OC'd to 4.4Ghz
It's going to be hot and you may need to delid
Want to custom loop?  Ask me more if you are curious
1 minute ago, HenrikDK said:
It should soon be done with processing
Oh man, I see the issue.  You're using a somewhat slim 120mm aio, you actually have pretty good temps all things considered xD
Many if not all 120mm aios get outperformed by similar priced air coolers. So don't expect magic. If you really want to lower temps, get a beefy tower cooler or a 240mm aio
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
Just now, Damascus said:
REEEEEEEEEEEEE
280mm is better IMO but you're totally right
My recommendation is a minimum recommendation, dont know what fits in the haf but a 240mm should definitely work. 280mm is of course better, 360mm is even better but even more compatibility issues
- Ryzen Build -
2x Dell UP2516D
I was thinking about CRYORIG A40 ULTIMATE
I just googled the fan config on the haf x, i doubt you can fit it without modding. My suggestion would be a big and beefy aircooler like the r1 ultimate from cryorig, nhd 15 by noctua or dark rock pro 3
- Ryzen Build -
2x Dell UP2516D
4 minutes ago, HenrikDK said:
The only problem is that i'm waiting for amd thread ripper or possibly i9. And if i buy a new cooler now, it would probably be a waste of money
Then live with it
You are in the save range of temps
- Ryzen Build -
2x Dell UP2516D
4 hours ago, HenrikDK said:
:/ Maybe i can, i'm trying out 4.2 ghz and i'm alot happier with the results. Btw is this normal? https://youtu.be/n0oz0Rf-iFY?t=59s
no it's not, but as you want to upgrade anyways to a new platform, leave it as is as it works right now kinda. The block itself seems to have enough mounting pressure to keep your cpu reasonable cool for what cooler type you've got.
- Ryzen Build -
2x Dell UP2516D
