peripherals lose power???
Solved by FireofDestruction,
2 hours ago, IntelBeastboy said:No, I'm saying the board should be fine, RMA it to see if it's that if not go back to the drawing board.
1 hour ago, NumLock21 said:Missed the part where you mentioned your board. so never mind about the Ai Suite. that's for Asus boards. Anyway in that utility, there is a option where you can disable power to USB ports or make it sleep when device is not in use.
after updating bios and waiting a bit to see if the problem had disappeared it seems to have gone as i've been watching yt while gaming must've been the bios update ty
