I am looking for a build that will let me play Overwatch/League of Legends at 144 fps on a 1080p resolution with very little frame drop. I already own the Corsair H100i v2 so please build around that. I do not have a set budget, but the cheaper, the better. I would be happy to invest in a 1080 and i7-7700K as long as it stays around $1500-1600 USD, however, I do not want to cheap out on other aspects of the build . As for storage, I plan to get a 250GB ssd and a 1TB hdd. I do not know much about Ryzen, but if someone could explain the pros and cons of Intel vs AMD in my situation, it would be much appreciated. I do occasionally stream LoL for some friends to watch. Sorry if this is all over the place but thank you for any help.
https://linustechtips.com/topic/793289-help-with-first-build/
For league a 1050 and an i5 or r5. That game is not intensive and ran on my integrated graphics laptop at 80 fps.
Overwatch 1070, 1600. Overall you dont need to spend 1500 1600 for those 2 games.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990127
If you are planning on eventually getting into harder to run games, I will make a list of parts for your 1500 budget..
My Rig
 Peripherals
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990133
I know i dont need to get those overkill products, but I want a nice pc, those are just the 2 games i care most about.
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990141
Would you like a window(rgb) or no window(a bit more silent).
My Rig
 Peripherals
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990145
2 more questions.
Do you need windows or peripherals included into the price.
1 tb hhd + 256  ssd will it suffice?
My Rig
 Peripherals
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990156
1 minute ago, cashan said:
buy something a little cheaper and invest in a nice monitor and some games or something
I am going to get a nice monitor but that is not included in the budget. I also dont play that many games and the ones i do are mostly free to play.
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990176
Ok so free to play games dont require a great pc. Ill try to make a pc thats cheaper than 1500 so you can get games that need actually need this overkill hardware.
My Rig
 Peripherals
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990207
I would still be happy with a 1070 so if you can make a build that can swap between them that would be great!
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990218
https://pcpartpicker.com/list/6vC4VY
Get non free games.
If you want get another version of 1070 or get a 1080
If you want change the storage. You can get a 520gb ssd mx300 instead of the hdd and ssd.
Windows costs 80 dollars.
You probably need 2 fans as well.
My Rig
 Peripherals
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990261
My Rig
 Peripherals
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990269
Get non free games.
Why do you choose Ryzen? Do you run Ryzen or know anybody that says it is more worth it than Intel
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9990557
Both, It has more cores and threads than a 7600k. It has a lower average but fps doesnt rise and fall rapidly like on the 7600k. You can get a 7600k if you want tho.
My Rig
 Peripherals
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9991099
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($299.39 @ SuperBiiz) better for streaming compared to the i7.
Motherboard: MSI - X370 GAMING PLUS ATX AM4 Motherboard  ($118.00 @ Amazon) order am4 mounts for your h100i if you don't have them already.
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($112.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($87.88 @ OutletPC)
Storage: Toshiba - P300 1TB 3.5" 7200RPM Internal Hard Drive  ($44.13 @ Amazon)
Video Card: Zotac - GeForce GTX 1080 Ti 11GB AMP Edition Video Card  ($694.79 @ SuperBiiz)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Total: $1527.16
Generated by PCPartPicker 2017-06-14 21:50 EDT-0400
https://linustechtips.com/topic/793289-help-with-first-build/#findComment-9991711
