Using SIM card for network
By
TomislaV
in Networking
in Networking
Solved by HTCv2,
We use this TP Link LTE Router (http://www.tp-link.com/ph/products/details/cat-4691_TL-MR6400.html). It functions as your normal router would with WIFI and ethernets, If you have bad reception where you live you can also install an external arial which you can place out side to get better reception.
HunterSVK ·
Posted in Troubleshooting1 -
Ozzi ·
Posted in Networking3 -
2
MadManMarsBar ·
Posted in Build Logs1 -
IAmAndre ·
Posted in New Builds and Planning7 -
4
3
Playgb2 ·
Posted in Troubleshooting2 -
3
2
play_circle_filled
Latest From ShortCircuit:
