Well, I've only just started to get into mining crypto currencies. So I was setting up the ethminer for OpenGL, I had run everything correctly as based off a tutorial, however upon running the command line meant to start mining I got an invalid argument error, I tried enabling and disabling crossfire on my AMD cards, I changed the command line to run on only 1 card and the for it to run on 2 cards. Basically, I tried all that I could think of. But I still got the error every single time regardless.
The original command line: ethminer -G -t 2 -F http://pool.eth.pp.ua/?miner=30@[my wallet address]
All the other cmd lines I tried:
ethminer -G -t 2 -F http://pool.eth.pp.ua/?miner=35@[my wallet address]
ethminer -G -F http://pool.eth.pp.ua/?miner=30@[my wallet address]
ethminer -G -F http://pool.eth.pp.ua/?miner=35@[my wallet address]
(My max hash rate is 35.63 MHs)
What shows up after I press enter below.
B:\Mining\eth_pp_ua-openclminer\ethminer-opencl-0.9.41>ethminer -G -t 2 -F http://ethereumpool.co/?miner=34@0x16f136950DB5B9D911d4a3F37867a037A3515300
Found suitable OpenCL device [Tonga] with 4294967296 bytes of GPU memory
miner  14:25:54|main  Getting work package...
miner  14:25:56|main  Grabbing DAG for #7c4fb8a5ÔǪ
miner  14:25:57|main  Got work package:
  i  14:25:57|<unknown>  Loading full DAG of seedhash: #3868abc5ÔǪ
miner  14:25:57|main    Header-hash: adcb4d586c00f609e73ddd523c44af3f7db93895a88f69a248b0094b2d788c36
miner  14:25:57|main    Seedhash: 7c4fb8a5d141973b69b521ce76b0dc50f0d2834d817c7f8310a6ab5becc6bb0c
miner  14:25:57|main    Target: 0000000050d8b080b6c49da43b2e24509239a3e0955186556a0fb92b803163a0
  i  14:25:57|gpuminer0  workLoop 0 #00000000ÔǪ #7c4fb8a5ÔǪ
  i  14:25:57|gpuminer1  workLoop 0 #00000000ÔǪ #7c4fb8a5ÔǪ
  i  14:25:57|gpuminer0  Initialising miner...
  i  14:25:57|gpuminer1  Initialising miner...
miner  14:25:58|main  Mining on PoWhash #adcb4d58ÔǪ : 0 H/s = 0 hashes / 0.5 s
Using platform: AMD Accelerated Parallel ProcessingDAG  14:25:59|<unknown>  DAG Generation Failure. Reason: Invalid argument
Any help will be greatly appreciated.
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/791201-ethereum-mining-issues/
That's a really non-descriptive miner they have and probably specific to their pool. I don't really know enough about it to comment much. It doesn't use Crossfire when mining, what driver version are you on?
I use the Ethermine pool with the Claymore's Miner which is better supported.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966630
Ah okay...yeah they said the latest driver version so I upgraded to 17.6 but I'm trying what you use, and downgrading to 15.12 Let's hope that works....
Desktop
LAPTOP
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966653
I'm seeing a lot of recent posts about a DAG generation error across different miners on Reddit and StackExchange. There must be something up with the Ethereum network if that's the case.
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966668
4 minutes ago, kb5zue said:
Ouch!  Just looking at your post reminds me why I am not a programmer.  But I do wish you the best of luck trying to make money out of thin air.  Or should that be thin internet?  Anyways.........................
Thanks! I'm trying to make money without working because I'm a lazy bugger xD .
Desktop
LAPTOP
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966669
Oh, I really do hope not....
Desktop
LAPTOP
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966672
It'll probably get fixed in the next couple of days. There is always Zcash to mine. :)
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966679
Hmm, I've gotten it to work now with the 15.12 driver but it doesn't recognise the Asia server for ethermine...
Desktop
LAPTOP
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966694
Are you still using the same miner from the previous pool?
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966698
Nope, I'm now using claymores...Actually nevermind its working now. Are you aware of any instability issues caused by mining and using chrome?
Desktop
LAPTOP
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966708
Nope, did you get a crash or something? I've only had that happen when my GPUs are overclocked.
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966711
Hmm, thats odd, when I was mining, chrome would freeze, apps won't open, windows key refused to work until when I closed the miner, all the actions I requested from earlier would execute in a split second.
Desktop
LAPTOP
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9966717
Some miners really take all of the graphics resources from your system and are pretty much unusable for normal tasks.
https://linustechtips.com/topic/791201-ethereum-mining-issues/#findComment-9968240
