I am planning on building this pc:
https://pcpartpicker.com/list/xPHdTH
But it is my first ever m itx computer and i havent found some exact informations such as:
will the ryzen 1600 stock cooler fit in this case?
How many exactly and the size of the fans that can go into this( i think that it is 5 80mm ones)
https://linustechtips.com/topic/790739-help-with-m-itx-case/
Hey man, the stock cooler is about 75mm tall with the fan
and I have a cooler master elite 110 case I'm using at the moment... it fits 1x 120mm fan OR 1x 140mm fan.
if you choose to put in a water cooler you have to go with a 120mm rad and 120mm fan.
I have 140mm intake at the front and use the PSU as the exhaust
https://linustechtips.com/topic/790739-help-with-m-itx-case/#findComment-9961555
Thanks, man!
https://linustechtips.com/topic/790739-help-with-m-itx-case/#findComment-9962375
