My build https://pcpartpicker.com/list/GHnfgL
What fans should I buy for the case. Im using the 2 default fans as outtakes on the rear, and on the top(closer to the rear). I want 2 140 mm intakes. Thinking of getting be quiet pure wings 2 no PWM. Im attaching all the fans to the motherboard and not the fan controller, and im doing 1080p gaming. 9 dollars pricepoint.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/790204-140mm-case-fans/
I don't know how the stock fans are, but keep in mind that the system will only be as quiet as the loudest element, meaning the Pure Wings won't help much if the default fans are way more loud.
While the Pure Wings are quiet, they don't move that much air. Silent Wings are equally quiet if not even slightly quieter - but they move more air. I myself upgraded to 120mm Silent Wings from 140mm Pure Wings and noticed a clear improvement in both acoustics and airflow, despite switching to smaller fans. However I had a different budget.
Asus X99-A w/ BIOS 3402 | Intel i7 5820k OC @4.4GHz 1.28V w/ Noctua NH-U14S | 16GB Corsair Vengeance DDR4 OC @2666MHz 12-14-14-28 | Asus Geforce GTX970 STRIX OC | EVGA 750 G2 750W | Samsung 850 Evo 1 TB | Windows 10 64-bit | Be-Quiet Silent Base 800 w/ Silent Wings | 2x Dell U2414H OC @72Hz w/ Display Port
Don't forget to invest in an Intel Tuning Plan if you're going to overvolt your K/X CPU
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955083
The noise level will be 23.5 dB(A) and the max airflow will be 50.6 CFM on the default fans.
My Rig
 Peripherals
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955097
Sadly those numbers never translate well into the real world as the chassi affects airflow and noise levels a lot. When I upgraded fans I too got stuck on the numbers and only got disappointed... in the end I had to order 5-6 different fans and try them out in various spots in my chassi and find the best one(s). Some may rightfully call it overkill, but my point is you can really only go on the reputation and popularity among quiet PC enthusiasts when deciding on fans.
Your fan setup looks decent for your budget, but if I were you I would decide beforehand what to do if the stock fans were to turn out to be a disappointment, just to avoid any sad surprises :)
PS. Check your text formatting
EDIT: A little extra - I'd recommend eventually checking out rubber pads/screws to mount your fans on to reduce vibrations if you really like quiet PCs
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955131
Well, if they are noisy, I might just deal with it fo 2 months and then get a new one. What do you mean by check your text formatting?
My Rig
 Peripherals
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955146
Sorry for sorta spamming you with messages, but I can buy some rubber pads to reduce vibration if they are under 5 dollars for a set of 2 fans. Can you recommend some?
My Rig
 Peripherals
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955159
Formatting - your text is invisible in dark theme website
Pads - check out Noctua Chromax ($7), the rubber screws, or the pads if you prefer them instead. I use the screws. There are of course other brands as well, but I've only had the Chromax ones.
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955187
Thanks, I guess I will keep my decision with the pure wings, and I will definitely check out the screws. Thanks.
My Rig
 Peripherals
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955198
One final question, do the screws version work with all fans?
My Rig
 Peripherals
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955218
They work with all fans, but apparently the front mounts in my chassi didn't like the rubber screws so I couldn't fit them there. I don't know if my chassi is weird or so, or if some chassis might not work with those.
You could always contact the support for the chassi and ask if the specific product would work.
https://linustechtips.com/topic/790204-140mm-case-fans/#findComment-9955254
