What games are you playing? Are they CPU intensive?
Also what motherboard ?
check my PC build here: https://valid.x86.fr/jyjc2n
b350 tomhawk arctic h.51 bios, Corsair LPX ram running at 3200mhz
case is a 35$ Zalman Z3 plus white with a cooler master 10$ (15MIR)hyper t4 cooler
20$ EVGA 450w bt (black cables)
150$ 1060 3gb@2.1ghz
https://linustechtips.com/topic/789370-ryzen-1600-memory-speed/#findComment-9944946
You will see a benifit on cpu intensive games like that. Since the GPU is not getting stressed as much on those types of games, the CPU becomes the bottleneck in this case.
I would say try to get the cheapest high speed memory that goes above 3000mhz or equal to.
You could also research which ram you can overclock on your board.
There is cheap ram like this 30$ 2100mhz crucial (micron) ram( https://www.newegg.com/Product/Product.aspx?Item=9SIAD7H5EX2061)  that people have OC'ed to 2933mhz (now 3000mhz) on b350 mobo's.
2933mhz 4gb crucial sticks https://forum-en.msi.com/index.php?topic=285450.0
https://linustechtips.com/topic/789370-ryzen-1600-memory-speed/#findComment-9955980
On 6/5/2017 at 7:05 PM, jorbesssss said:
Im planning to get a Ryzen 1600 and a gtx 1070 for 2560x1080p gaming.
I wondering what memory speed should i get
2133, 2400, 2666, or 3000mhz
 I mean if the difference is only like 3-5 frames in games i would prefer the cheaper one!
3000 all the way! the frequency of the memory dictates the speed of the infinity fabric that laces the cores together. there is a SIGNIFICANT difference between 2133 and 3000 ram on ryzen.
13700k, 3070, 32GB@3200
https://linustechtips.com/topic/789370-ryzen-1600-memory-speed/#findComment-9956071
Significant is depending on which programs you are running.  Since we're talking games, most AAA titles are GPU bound, but the CPU does help. Running 2133 Ram at C16 would be a bad choice, but dropping a ton of 3200+ ram is a waste of money (personal experience).  Running an 1800x on 3399 ram atm, and I only get a 3-5 percent improvement over 3200. The change from 2133 to 3200 though is more like 10-30 percent depending on the title.
To the OP: Go with a middle ground. 3000 is really a middle ground as 3200 would be considered ideal (or faster but much less stable).
https://linustechtips.com/topic/789370-ryzen-1600-memory-speed/#findComment-9956244
